help with oil dipstick - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2008, 12:10 PM
chewyscool's Avatar
Big Block 454
I need to install the new dipstick I got for my SBC. The old one pulled out and the new one is much tighter in the hole. Any suggestions or home made tools for the install. Its a chrome dipstick for early sbc and I dont want to beat the crap out of it.
Old 12-14-2008, 02:36 PM
327NUT's Avatar
Well if it's the curved type that has the chrome tube that fits into the block and then the dip stick slides down into it.....then its a TIGHT FIT. These items are not so to speak "CNC" machined. You may have to stick it in a vise and using some sand paper or emery cloth take a "few thousands" off of it. You will probably have to use a close fitting open or closed end wrench around it and then TAP it in...it's a file and fit type of deal.
DON'T do like a guy I once knew did...he drilled out the hole in the block!!! He was advised by another freind "are you nuts!!" After he dropped the pan and cleaned out all the metal shavings he was asking himself the same question.
Old 12-14-2008, 10:47 PM
chewyscool's Avatar
Big Block 454
I wouldn't think of it, thanks for the tip.
Clean oil leaking, dirty oil on the dipstick? frankenvette Engine 7 10-02-2006 10:06 PM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 02:51 PM
Oil dipstick Novaman78 Engine 9 08-05-2004 10:58 PM
HELP! 360 Gushing Oil out dipstick dadeeoo Engine 5 04-20-2004 02:42 PM
TH350 - will oil spew from dipstick hole?! Limey Simon Transmission - Rearend 3 03-27-2003 01:42 PM
