Help, paint runs......
I am clearing my front bumper cover and have created severe runs. I did this today and would like to continue adding coats tomorrow, how do I remove the runs?
Jim |
Ditto to above, and when you use a block to sand the remainder out make
sure it's a very hard block, not a rubbery one, I usually use a wood block that I sand flat before using it. I've taken a lot of runs out this way, it's really not that hard, provided you have enough clear on it. |
The single edge razor blade it the best no doubt.
I just dull the ends on a grinder lightly and as long as you keep it straight up & down you'll be amazed.Yeah it will scare you at first,but you'll get the hang of it. You will NOT scratch the good clear,it will just scoot across it. You can also bow the blade for some non flat areas. |
See the last two entries on this page. And quit piling on the paint!!
Willys: I have never tried this, that's neat!
Am I understanding this right? You're not "slicing" the paint but rather scraping by holding the blade 90 degrees to the surface? |
Yes it's a scraping action. That's why I linked to the cabinet scraper web site 'cause the principle is identical.
Sounds like you guys have had as much practice as me
. Also after you get it scraped down as far as possible, lightly go over it with something like 800 grit to get it down the rest of the way before starting with 1500 -2000. If you start with to light of a grit your only polishing the hump.Craig |
Yes, I am runny boy! Good point on the lump. May take a couple of scrape/polish rounds to totally eliminate the hidden lump. Once you do it a couple of times, you get a feel for when you are level with the surroundings.
Yeah, If I don't get a little run somewhere when doing a complete I feel as though I should have put it on a little wetter
It's usually a tight corner that gets a drip running out or something similar, tail light pocket, etc.
I agree. A run only indicates that you have put enough material on!! Also, Mequires has little sanding stones in grits ranging from 400 to 1500 and maybe even 2000(can't quite remember). |
| "Basic of Basics" Can I use "rattle can" paint on my car? | Centerline | Body - Exterior | 33 | 07-08-2011 12:33 PM |
| what else in in wax and grease remover besides mineral spirits? | Dubz | Body - Exterior | 47 | 06-19-2010 12:09 PM |
| Sherman Williams Clear Coat Failing < 3 Years? | DeJarnett | Body - Exterior | 33 | 12-11-2005 10:39 AM |
| Looking to paint my car with OEM quality finish. Have some Questions | Gro Harlem | Body - Exterior | 12 | 01-15-2005 06:31 AM |
| Picking a color | Wmarden | Body - Exterior | 6 | 10-23-2004 11:13 PM |
