I would go with the kirker or go to SPI for primers and clears..Scrub with Dawn dishwashing soap and scrubbers then w&g remover and then sand with 80 grit..then prime an go base clear as this is the easier way in my opinion..once the primer is on then do your blocking and filling steps followed by a coat of primer sealer..sand with a 320/400 and then base coat followed by the clear..This is the time tested general procedure for paint..
Good luck
Sam
