Help with painting - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-29-2012, 08:48 AM
Help with painting
Anyone ever use Eastwood, paintforcars, or Kirker paint products? I am going to attemp on painting my sons 1985 chevy short bed. He wants to paint it metallic silver or gray. Does anyone know how the single stage paints hold up, or should we use the base coat / clear coat? Also, any pics would be great. Thanks
Old 02-29-2012, 09:34 AM
You paint selection is a combination of factors, will the car be garaged and out of the elements most of the time?, if so about any singlestage product will work well. Will it have to live outside all of the time, then a singlestage product will experience the same fate of dullling and needing polishing and waxing to keep up the finish. Clearcoats will do better if outside all the time. I think the amount of money you spend on paint should be relative to the value of the car, spend 10G on a 100 grand car, spend 450 on a 5000 dollar car.
Old 02-29-2012, 10:43 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would go with the kirker or go to SPI for primers and clears..Scrub with Dawn dishwashing soap and scrubbers then w&g remover and then sand with 80 grit..then prime an go base clear as this is the easier way in my opinion..once the primer is on then do your blocking and filling steps followed by a coat of primer sealer..sand with a 320/400 and then base coat followed by the clear..This is the time tested general procedure for paint..
Good luck
Sam
that is a very good answer to his question i needed that info too thanks
Painting first car!!! Help Bandit80 Body - Exterior 17 04-25-2010 10:47 AM
About painting e_leveriza Introduce Yourself 1 08-11-2007 12:57 AM
painting sparky-14volt Body - Exterior 4 10-06-2006 11:21 PM
New to painting metal4130 Introduce Yourself 2 07-27-2005 12:24 AM
Painting OF your car? nitsud08 Body - Exterior 9 04-12-2005 09:38 PM
