Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help picking gear ratio
Old 12-01-2012, 07:24 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
you have 4 degrees more duration on the exhaust side?you didnt say the LDA of the cam.If you have a turbo header with that cam? the duration is wrong way for split.
This engine should break the tires loose with 2.7 gears.how many cfm does your turbo charger system move?
