Help picking gear ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2012, 07:41 PM
Pupsvette76's Avatar
Last journal entry: no spark and fuel pump issue
Hey guys I need some help picking the right hear ratio for my car it's a 70 chevy nova with a sbc 355 with afr 215 heads 75cc chamber edelbrock roller cam .539/.540 lift 234/238 duration at .050
Single plane intake manifold professional products efi a gt45 turbo at 15-20psi b&m hole shot converter 3000 rpm in a turbo 350... Any help is appreciated
Old 11-28-2012, 07:58 PM
prostreet6t9's Avatar
Differential/Driveline
How tall is your tire??
Old 11-28-2012, 08:45 PM
It's a 295 50 15 =27inches tall
Old 11-28-2012, 08:54 PM
big gear head's Avatar
High Performance Rear Ends
What will you be using the car for?
Old 11-29-2012, 07:51 AM
Traditionally, turbo cars do not like a ton of rear gear. I would say somewhere in the range of 3.55:1 - 3.31:1.
Old 11-29-2012, 09:03 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Not trying to one-up anybody but my old single axle med. duty dump truck has one of those 2 speed rears, Eaton, get this- 6.50-8.85!.. The spicer 5 speed is 1:1 in 5th!.. Of course 11r 22.5 truck tires, but wow does she have some gear..
On topic, I like a combo for the street that gets you right at 10:1 in first gear, all in, through the tires.
Old 11-29-2012, 10:39 AM
^^What he said!
It seems like the turbo like a little load put on it.
Old 11-29-2012, 11:47 AM
vinniekq2's Avatar
If you are racing then you need some tires first.The trans wont last long
Old 11-29-2012, 05:59 PM
As Autogear stated... I'd shoot for a 331 or 355 gear.
Old 11-29-2012, 07:43 PM
Bye Jerks
Larger diameter rear tires ( 29" slicks )
3.73:1 gears
Powerglide tranny.
Old 11-30-2012, 03:53 PM
Currently there are 4.88 in it and I can just feel the engine running up in rpm to quick to make power... The gear I have doesn't allow much time in each gear and it pulls me out of my powerband
Old 11-30-2012, 04:25 PM
vinniekq2's Avatar
does it run ok with that cam?
Old 12-01-2012, 06:20 PM
It runs good I didn't wanna run a huge lift cam or a huge duration cuz I didn't want any piston to valve clearance issues
Old 12-01-2012, 08:24 PM
vinniekq2's Avatar
you have 4 degrees more duration on the exhaust side?you didnt say the LDA of the cam.If you have a turbo header with that cam? the duration is wrong way for split.
This engine should break the tires loose with 2.7 gears.how many cfm does your turbo charger system move?
Old 12-04-2012, 03:54 PM
I'm 23 and only been putting engines together for a few years so I'm kinda new to all the terms what is LDA? Do u mean LSA?
Help picking out gear ratio xxllmm4 Transmission - Rearend 3 10-04-2012 12:09 PM
Richmond Gear 5-speed,Why all the first gear ratio options? Argess Transmission - Rearend 1 10-17-2011 08:11 AM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 12:32 PM
picking rocker arm ratio? slow'n'steady Engine 0 05-02-2007 10:47 AM
Help picking gear's "70" Cougar Transmission - Rearend 9 03-16-2006 12:05 AM
