3.89 3.73 or 3.55:1 would be fine for 1st gear performance and the 3.55 would have a modicum of relief on the highway. However, thats the easy part, what you really need is a QUALITY converter, with the right stall and proper diameter for the intended application
that 120 shot is likely adding 200 pounds of torque.that cam is not super high revving so go moderate on the gearing.It will likely eat tires. I use a mild 3.5 gear in my car,the engine revs 6500 and its light weight. 3.9 gears would help you decide to get an O/d trans mission later
| need gear ratio | Buckeye Bob | Transmission - Rearend | 7 | 11-20-2011 06:40 PM |
| Richmond Gear 5-speed,Why all the first gear ratio options? | Argess | Transmission - Rearend | 1 | 10-17-2011 07:11 AM |
| Rear end gear ratio change = spedo. cable gear change. help? turbo 350 | sugar ray | Transmission - Rearend | 6 | 07-18-2007 11:32 AM |
| picking rocker arm ratio? | slow'n'steady | Engine | 0 | 05-02-2007 09:47 AM |
| Help picking gear's | "70" Cougar | Transmission - Rearend | 9 | 03-15-2006 11:05 PM |
