Help picking rear gear ratio - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-18-2013, 04:37 PM
Pupsvette76's Avatar
Last journal entry: no spark and fuel pump issue
As far as gears go 3.55 was the exact gear I was thinking about using ... What exactly makes turbo cars run better on a lower numerical number
  #17 (permalink)
Old 09-18-2013, 05:40 PM
Proud LOSER
One word....
LOAD
456 gear means in boost quick, and shift......not exactly optimum for building or using boost....
355 gear means its going to load the turbo as the motor builds rpm.....and keep building boost for a longer time.....shift....rpm drops.....back into a longer window of boost.
  #18 (permalink)
Old 09-18-2013, 08:00 PM
That makes perfect sense thanks a lot for the explanation
  #19 (permalink)
Old 09-21-2013, 07:38 AM
vinniekq2's Avatar
I think if I had this car,I would change out the turbo 350 when I did the converter. something a lot stronger to take the daily torque. This is going to be expensive
  #20 (permalink)
Old 09-21-2013, 09:22 AM
Proud LOSER
Yah, when its all said and done it will likely be a very expensive TH350 to live behind as much power as this is or could make......Ida done a built Glide myself......that motor set on kill should be ridiculous......
Help picking gear ratio Pupsvette76 Transmission - Rearend 14 12-04-2012 03:54 PM
Help picking out gear ratio xxllmm4 Transmission - Rearend 3 10-04-2012 12:09 PM
Need to ID this rear differential and gear ratio beachbum0 Transmission - Rearend 16 08-05-2012 04:33 PM
Rear gear ratio ? newportman Hotrodding Basics 3 02-14-2011 09:04 PM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 12:32 PM
