I got the 3.294" thrust plate and over the weekend i bolted it up to check the fit and it bolted up fine. Im just waiting on the cam now from summit. The invoice said it should be shipping out today because they had to order it but we will see. I got 1/4-20 x 3/4" bolts from the local hardware store and they are actually a little too long for my application. Ill have to get 1/2" long bolts sometime this week.
Let me know how that cam works out for you. I've been looking at that one for a while to replace my prc108 cam. Let me know about power, mileage, idle vac, etc. It looks to be a good hot street cam.
I lost track of what p/n cam and the lift of the cam you are thinking about using. I don't think it was ever said what the specs were for the lift before there are problems, so I looked it up in another post I made on this.
Regarding the problems associated w/higher lift cams and the stock dog bone lifter retainers and lifters, from HERE: Quote:
Adjust valves. |
Well got the cam put in these past couple days with the exceptionally beautiful weather. Started right up first time and sounds awesome idle is smoother than I expected for 108*LSA.
hopefully in the next couple weeks ill go through and check over everything and get it put on the road so I can get the rings sat. I only have maybe 10-15 miles since I put new cast rings in it and they are a lot better than when I first drove it but its still smoking pretty bad. Hopefully in 33 days when the track opens I will be able to post some time slips and maybe some videos. Right now I haven't really been able to figure out exactly what the car likes for timing and such but initial is about 22* and total is at about 33-34 and I get about 13" of vacuum in gear idling around 1000 rpm and in park I get 16-18" of vacuum at about 1200rpm.... when I turn down the idle to say 900-950 in park I get about 14" and in gear about 10-11" of vacuum... I still have a lot of playing around with it to get it to idle the way I want and running good. But thanks again to everyone who chimed in on the build and was able to point me in the right direction! |
Well I finally got some time today to give howards a call for valve springs and they told me that cam requires 135lb on the seat and 350-360lb open. Can anyone throw out any suggestions? I wanted to try out comp beehive springs but I don't see any within that range.
They only springs I see on summit have an installed height of 1.800". I believe SBC are set up or 1.700" so does that mean I need to run a +.100" valve or do they make valve locks that will offset the retainer by .100". I have seen .050" but not .100". Thanks for all the help. |
They have .050" locks and the retainer can affect the installed height. You can also cut the seat or get new longer valves. Stock installed height can vary, and is affected by the vj. The only way to know is to check it.
Will any of these work?
http://www.summitracing.com/parts/CC...n/?prefilter=1 http://www.summitracing.com/parts/CC...n/?prefilter=1 http://www.summitracing.com/parts/HR...n/?prefilter=1 How close do I have to be to the 135 open and 350-360 seat numbers? My only problem with the last one is that the installed height is 1.880" But maybe with +.100" and a .050 lock and a new valve job I can make it work Last edited by zildjian4life218; 05-10-2012 at 07:20 PM. |
| Roller Rockers to use with Vortec heads??? | GUITAR1989 | Engine | 5 | 06-02-2011 05:24 PM |
| vortec roller cam help | footjoy | Engine | 3 | 03-31-2008 11:04 AM |
| vortec heads & hyd.roller cams | BourgD | Introduce Yourself | 1 | 07-22-2007 12:29 AM |
| best roller cam for vortec heads | 11secmudtrk | Engine | 6 | 01-18-2005 09:38 PM |
| Vortec - roller rockers? | dev | Engine | 2 | 09-20-2004 05:05 AM |
