Help with picking roller cam for Vortec 355 - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 05-11-2012, 01:47 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by zildjian4life218
howards - 180325-08... even with the cam NOT having a reduced base circle will I have this issue? and thanks for the links. I will read through them.
The base circle will be whatever diameter that is needed to get the advertised valve lift. That means the base circle diameter can be less than a stock cam, even though the cam's not advertised as a "reduced base circle" cam.
The limit is 0.354" lobe lift, which is 0.531" valve lift using 1.5 rockers. You are right at this limit, so check VERY carefully, or use taller lifters made for more lift than the stock pieces.
  #77 (permalink)
Old 05-11-2012, 08:06 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Thanks for the replies everyone.
Ap so all I need with those are the special .050" keepers and a set of retainers?
Cobalt when I installed the lifters I didn't notice any of them going down any further than the lifter ties. Should I be alright cause of that?
  #78 (permalink)
Old 05-11-2012, 08:40 AM
Listen and Learn
Wiki Edits: 7
What does everyone think of these? Will they work with the springs AP suggested? I am probably gonna go with 10* degree locks just cause im replacing everything anyways and the prices are the same. Im thinking about these retainers
http://www.summitracing.com/parts/HRS-97132/
and these locks...
http://www.summitracing.com/parts/HRS-93085/
It says .050" installed height.
  #79 (permalink)
Old 05-11-2012, 09:27 AM
Banned
Your different retainers will change the installed height, it never stacks up the same, btdt. I installed those springs on an lt1 and the guy was pleased with them so far. I'm not sure where the .530" lift comes from on the cam measurements but I've heard it before. Again, nothing stacks the same from engine to engine so just check yours.
  #80 (permalink)
Old 05-11-2012, 05:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I wish I could say w/certainty exactly how much engagement of the lifter to the dogbone is the bare minimum required for safe operation- but I can't.
My best advice to you is if you are going to err, err on the safe side. See if you can find a minimum amount of engagement cited elsewhere instead of going by lobe lift- there are too many variables for that to be really effective IMO.
Originally Posted by ap72
I'm not sure where the .530" lift comes from...
From Crane's Director of Valvetrain R&D, Mark Campbell.
  #81 (permalink)
Old 06-07-2012, 09:03 AM
Listen and Learn
Wiki Edits: 7
Sorry I keep digging this up but I am finally gonna order the springs/retainers/locks.
Just got around to dropping the heads off at the machinists to get looked over. Will the locks and retainers work that I posted before?
I noticed the retainers say 1.250" outer spring and I think the ones AP suggested are 1.265". Does this little distance not matter? Would anyone suggest a different set?
  #82 (permalink)
Old 06-07-2012, 09:09 AM
Banned
call competition products.
  #83 (permalink)
Old 06-07-2012, 10:06 AM
Listen and Learn
Wiki Edits: 7
Alright Ill do that in a bit on my lunch break. Summit has those three part numbers all listed as suggested parts for each other so im assuming they should work together.
Roller Rockers to use with Vortec heads??? GUITAR1989 Engine 5 06-02-2011 06:24 PM
vortec roller cam help footjoy Engine 3 03-31-2008 12:04 PM
vortec heads & hyd.roller cams BourgD Introduce Yourself 1 07-22-2007 01:29 AM
best roller cam for vortec heads 11secmudtrk Engine 6 01-18-2005 10:38 PM
Vortec - roller rockers? dev Engine 2 09-20-2004 06:05 AM
