Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help picking a welder
  #20 (permalink)
Old 09-07-2011, 08:32 PM
willowbilly3's Avatar
willowbilly3 willowbilly3 is offline
Last journal entry: Body mods
Since I don't have 220 capability in my garage I use a Miller 140 wire feed on 75/25 gas for the light stuff and outside I have a Lincoln 200 amp portable for the heavier stuff. It's all personal preference but most of the welding shops that do work on the plants ect. around here won't use a wire feed on critical structural stuff and I tend to agree. If I was welding a truck frame I would definitely lay it in with a stick welder. For one thing you have a lot more choices of rod types, even though I would probably use 7018. The standard wire used in wire feeds is a little brittle from what I've been told. I have zero experience with a Tig so I can't comment on that.
