the number your looking at is just a casting number for the differentil.the axle code you want can be found on the passinger side axil tube 3inches from the differential faceing to the front of the car.you might have to use a little sand paper to claen them upso you can read them.the code will look like this 6jj c24 2,the first three are your axil codes and you can call your local gm dealer parts department and they can look them up.acheap hayne reapar manual from a parts store will also list them.
If you you can get the axlecod from your car I can probably look them up for you.Thanks for the trans info
