Help please car won't stop - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2009, 10:03 AM
raiderdave007's Avatar
I have 71 monte carlo and almost everytime I turn key off car won't shut off I replaced ignition switch and it still dosent work any ideas please help stressed out thanks dave
Old 10-15-2009, 12:41 PM
klutchmaster427's Avatar
Last wiki edit: Automobile body and frame rotisserie
Last journal entry: Bell Crank Fix
Wiki Edits: 4
Does it just keep running like normal or does it "diesel"?
Old 10-15-2009, 12:52 PM
Runs like normal its not dieseling thanks if u got some ideas please share
Old 10-15-2009, 02:31 PM
T-bucket23's Avatar
Wiki Edits: 26
Your alternator may be back feeding your ignition system. More info would be helpful as to what electrical modifications have been done. Sometime a diode is required in the alternator feed line. If you search for diode on here you should get the information you need. You can prove this issue by disconnecting the alternator and start and shut down the car and see if it shuts off.
Chet
Old 10-15-2009, 02:53 PM
So on a 3 wire alternator I unplug the 2 wire clip on top or fat cable on bottom
Old 10-31-2009, 03:32 PM
fast68's Avatar
likes chevy trucks & boobies
has anyone done any wiring work on the car? something is definitely feeding back to the ign coil.
definitely try disconnecting the alt and then see what it does.
Old 11-06-2009, 08:11 PM
dklong's Avatar
is there a electric fan hooked up to the ignition switch, if it is it could be back feeding the electrical system, I have seen this happen a few times when you turn the car off the fan become a generator and some times they'll run for afew minuites.
Painting a Metallic in pieces Polish Painter Body - Exterior 18 09-11-2010 06:16 AM
donk or lambo's got nothing on this 406chevycaprice Hotrodders' Lounge 28 01-28-2008 08:09 AM
a true story abount my first car chopperdave70 Hotrodders' Lounge 7 01-26-2008 06:13 PM
A lot more effort to stop the car after new brake parts were installed? HotRodMan Suspension - Brakes - Steering 8 05-01-2004 02:27 PM
