Help Please...Low CFM gun - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-10-2007, 12:30 AM
Originally Posted by ken_c
Why not try the Iwata knockoff "Zhipp" gun off ebay?
I compared it to my LPH400, and the Zhipp uses less air.
I'm not saying it's a better gun, but it is a surprisingly good gun and uses less air than any gun I have short of my Sharpe Platinum. Plus it's about $50!!
Thanks, i'll difinitely look into it
  #17 (permalink)
Old 05-10-2007, 12:34 AM
Originally Posted by oldred
The 43430 takes a LOT of air and I think most everyone that uses one can attest to that. I bought the 43430 after hearing about it here, bought 2 of them actually, and I was quite pleased with the performance but I have a large compressor and air supply is no problem. When you say 30 gallon compressor I have to assume it is a low CFM so I am afraid when your friend starts on the outside of the car he may have serious problems unless he paints the car in parts and not all at once. To better help decide which gun you need forget about gallons and use CFM as the guide to how much performance you can expect from a compressor since tank size really don't mean much in spite of common belief, it is how much air the motor/pump (CFM) produces that matters. There are several guns around, some already mentioned, that should work just fine with the compressor you have so I would suggest you look for one that requires about 6 or 7 CFM and no more than that, the 43430 needs about twice that much. A bigger compressor would be the best way to go but with a little planing and air management along with the proper gun you should be able to get by ok.
Thanks oldred. Now i have better idea of what's good to get. Also thanks for the tip. I will take that into consideration Thanks everyone for you input
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
VE, CFM from Injector Flow & RPM NXS Engine 0 07-03-2005 02:11 PM
compressor CFM AhX Body - Exterior 3 04-03-2005 02:20 PM
Low CFM HVLP guns Blackdog Body - Exterior 1 11-01-2004 07:59 PM
Eastwood's Rubberized HUMAN coating gun. WATCH OUT Pencilneck314 Body - Exterior 9 06-20-2004 09:56 PM
