Help please...no a/c or heat from vents - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2005, 02:27 PM
I have an 82 trans am with a 305 carb...all of a sudden after only using the a/c after 5 minutes i have nothing comming out of the vents no matter what mode the control unit is in....the clutch isnt even engaging on the compressor in the on position,when i jumped the wires to the blower and ac compressor they worked, i put a new relay on there and still nothing, i jumped all the wires and all make connection no breaks....i changed the fan switch control unit and blower relay and still nothing....but everything works when i take power directly to it....i changed the reistor in the heater box and the blower switch in the control unit and now still nothing...im really lost please help.
Old 07-15-2005, 03:23 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Just a few guesses here,
Have you any access to A/C gauges to check the pressures? I don't always like to recommend this, but have you jumped the high and/or low pressure switches to see if the A/C clutch kicks in? (if it does, I'll bet you are low on Freon-low pressure). I assume that your car doesn't have an Automatic Temperature Control. It could also be the Thermo Switch-check the pressures and switches first-
Craig
Big block S-10 a/c heat daily driver roadrash9r Engine 3 06-27-2007 09:11 PM
Help please...no a/c or heat from vents knightriider Introduce Yourself 1 07-14-2005 08:29 PM
1951 Buick Roadmaster a/c system madgift Interior 3 08-13-2004 07:49 PM
A/C vents stinky jinx Interior 1 04-27-2004 10:13 PM
A/C question Paco Engine 1 06-03-2002 07:01 PM
