Help with plug read
About 500 miles on this. Some WOT's, last 5 minutes at idle. Its in the 383 stroker
[IMG] [/IMG]
If you really want to know what is going on in each cylinder by way of reading plugs the proper way is to make a wide open pass through the quarter mile on fresh plugs and then immediately shut down the engine.Then you need to either hack saw or grind off the metal jacket thread so you can read the plug properly for fuel ring mark ect.
While sensitive to these things it is also sensitive to engine operating temperature, and sparkplug heat range as well as a host of other operating conditions. All of these items can and do create conditions that mimic each other if one or more are off the norm. For instance a plug with too hot a heat range will look like the mixture is too lean, the engine is operated too hot, or the timing is excessively advanced; the plug will be white and fried looking. At the other extreme a plug that is too cold will look like the fuel mixture is too rich, the engine operated too cold or too little, the timing is not sufficiently advanced, a cam lobe is wiped out, a valve is leaking, a plug wire broken, too much gap and on and on the list can go. The plug will be black and perhaps wet thoug wet can just be that cylinder had just intaked but the ignition was cut before the plug fired. When you look at a plug as a means to get maximum performance you have to be able to figure out if everything is working properly or whether a failure in one place is off set by an opposing failure someplace else that could result in a perfectly normal looking plug. Of if the plug indicates a failure, then you need to track back to the Root Cause or causes. Bogie |
definition 1) Do what works to snap your neck definition 2) Do what the book says each time I'm going with the first. The guy at edelbrock tech said and I quote "You should really have your vac line on the timed port. Personally I put them in the trash can" |
Read that 3 or 4 times before you repost |
Well, tell me this. If your car launches and runs so damn good, why are you here posting about plug colors? Is it just you want to FIGJAM yourself (F@*$ I'm Great Just Ask Me)? Help me understand.
1. Starts-up trouble-free, hot or cold. 2. Idles the same, hot or cold. 3. No hesitation at any time...basically trouble-free/reliable. 4. Decent power for the parts installed. Even if I sacrifice some power to attain all of the above, so be it. If I could "have my cake and eat it too", I would. But once I try taking an engine out of it's sweet-spot, one of those things above suffers. edit: And just as a note, some engines I built were identical the previous engine I built. But no two were ever alike. Little bit different adjustments/settings here and there were required. But once the sweet-spot was found, I was done. |
Read A1supersorts post,he sums it up |
| 2001 Nissan Altima Spark Plug Wires | awbazar | Electrical | 5 | 11-07-2010 01:47 PM |
| spark plug questions | GT_80 | General Rodding Tech | 5 | 06-10-2010 11:18 AM |
| Spark Plug brands question | Francis | Engine | 65 | 07-15-2008 12:01 AM |
| recomended spark plug.. | screamin340 | Hotrodding Basics | 2 | 11-18-2005 07:17 AM |
| Oil Galley Plug Under Rear Main on SBC??? | camaroman7d | Engine | 16 | 02-19-2004 02:30 PM |
