Help with Power glide trans.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2011, 10:39 PM
life is a temporary assignment
I have a t-bucket I'm working on for a friend... It has a 350 Chevy motor with a power glide trans in it... There is holes in the bell housing and look's to be air cooled..(not sure if someone cut them are not).. Now the TC doesn't look to have any type of fins on it... So my question is.. How can I make sure if it needs a cooler are not ?? I want to be sure being I never set up a power glide before...Would it hurt to run one or what.. Thanks in advance.. Randy
Old 06-05-2011, 12:38 AM
Air cooled glide
What you have is an air-cooled powergllide/ Good transmission. The holes are factory. Really simple and reliable trans. I would have a powerglide many times over before a 700r4. Just get yourself a rebuild kit, new direct drive drum(summit) and drive on. Powerglides are so simple that if you are over 12 years old and know how to read, you can rebuild one. It really doesnt need a cooler in a T-bucket, (no weight to pull). Should be fine for another 75000 (thousand) miles with a rebuild.
Old 06-05-2011, 01:29 AM
SSedan64's Avatar
The TC also had a cooling shroud on it, can be seen here on Pg. 18 & 19.
http://www.transparts.ru/pdf/tc_gm_03_web.pdf
Old 06-05-2011, 02:02 AM
junior stocker's Avatar
Are the fluid cooling ports plugged? That should give you some idea on how it was set up/built. Many air cooled Glides have been used for parts, or upgraded to function with a fluid cooler circuit. A converter with a shroud, and a "turbine" sheet metal, converter cover, AND the bellhousing holes is what makes it an air cooled unit. Those appear to be missing, except for the bellhousing holes. There should be a cooler by-pass valve in the front pump assembly; it diverts fluid if the trans fluid cooler becomes plugged, cooler lines get bent up and closed off, or if the trans does'nt have a functioning, fluid cooler, circuit, such as when it's an air cooled unit. IF possible, run an external fluid cooler; heat kills an auto trans. The Glide I built, and we installed in my nephews 350 powered, 51 Chevrolet Business Coupe, does'nt have an external fluid cooler, and has the standard style, converter cover. It does'nt seem to get too hot, but it also has'nt been driven very far at a time.
Old 06-05-2011, 09:55 PM
Thanks guy's.. I just wanted to make sure that it was OK to add a cooler, Or do I have to also change something inside to run the cooler... The TC seems to look like a basic TC, Doesn't seem to be a air cooled one... This car has been siting for the last 20 years..I'm redoing the whole thing...The lines looked to be plugged off,, Didn't see where there was some on it at one time... But the whole car was a big mess.. So I'm just trying to make sure I don't make a wrong turn here..Thanks
To Power Glide, Or not to Power Glide 68Elcamino Transmission - Rearend 3 06-25-2010 06:59 AM
350 Power glide chappell Transmission - Rearend 4 03-21-2008 11:47 AM
Power Glide jmbjs Transmission - Rearend 7 04-21-2007 02:30 AM
power glide? nitro_baller4692 Transmission - Rearend 1 09-24-2006 05:19 PM
Question / Power glide trans W/OD ??? 1939P7 Transmission - Rearend 14 02-19-2006 02:37 PM
