Here the information your require:
PPG’s Deltron® 2000 (DBC) Basecoat is a state-of-the-art, premium quality basecoat/clearcoat system designed to reproduce the hi-tech O.E.M. finishes found on today’s import and domestic vehicles. Deltron® 2000 (DBI) Interior Color was developed for interior and underhood color matching purposes. It is mixed directly from the Deltron® Mixing Service. DBI must be reduced with the appropriate DT Reducer and does not require clearcoating. Please note that one is "DBC" and the other is "DBI" The DBI is an interior paint. The DBC is "Deltron Base Coat" it requires clear coat. Both require Activator and a Reducer. Frank Cox Cox Custom Cars |
Any idea why it says "This technology is an easy-to-use as a one or two-component solvent-borne technology" ? Has Deltron EVER made a high gloss single stage ? I have no idea how old this paint is, I do know it still looks good, and the can is in good shape. I also forgot to ask about reducer, Ive always herd that PPG paint is very picky about its reducers meaning no other reducer can be used but the deltron. Is this true as well? And I was just reading more about the Deltron, when I noticed it says "to clear coat in 20mins, but after 24hrs it must be sanded and re-coated with the base before clear coat" Is this a bonding thing, Or if I deside to let the base cure before clear will it raise up on me? I dont plan to wait 24hrs, just geting the feel for the new to me paint. thanks for the fast reply! |
I used PPG Deltron on my 34 and I loved it, it was very easy to use. I did not use activator on the base coat, only in the clear. PPG Deltron is urethane, PPG does make a single stage but the name escapes me at the moment. If all they gave you was the base you do not have enough to complete the job. You must clear coat it with an activated clear.
For best results it is ALWAY advisable to use the PPG reducers with PPG Deltron bases. That is true for any paint IMHO, I would never mix bands of paint and reducers that is just asking for trouble. PPG has spent tons of money engineering their entire system to work together. The re-coat window is a suggestion. Just about any base will require a scuff and reapplication of base after 24 hours to obtain the proper adhesion with clear Vince Last edited by 302 Z28; 12-01-2009 at 07:34 AM. |
Its a polyester (basically lacquer), just like chromabase. I've shot both, chromabase in the shops I've worked in years back, and always went down and picked up ppg if I was doing something on the side at home. I prefer ppg dbc over dupont chromabase. Its seems just a little more user friendly to me, as well as coverage a bit better. Plus the ppg uses no stupid basemaker, so any quality urethane reducer can be used to reduce it. Haven't shot chromabase in quite a long time, and been a couple years since I shot dbc, as I've found some good products that ain't so dang pricey as the majors.
Dbc would be basecoat, I believe they also call it 2000, which is most likely what you have and will need to be cleared. PPGs other base is dbu, but that one is like chromabase, and it uses a special reactive reducer. PPG's single stage in the deltron line would be called dcc-concept It shouldn't be too much different then shooting chromabase, and most colors should cover pretty well in 2 to 3 coats-not always the case but usually. You dbc base doesn't have to be activated. From what I remember it mixes 1 part paint to 1 part dt reducer (If you don't want to purchase the dt reducer, any urethane reducer from a good line should work-not low line omni or nason crapola, nor basemaker since its not ordinary reducer). I think it has the option of activating also-been awhile since I looked at the product data sheet on dbc. Not a bad idea at all to activate it for better durability and repairability. If you don't want to buy ppg's activator, you could instead add a capfulls worth of the hardener from the clear your using per mixed quart of base (don't pour base thats been activated back into the can with unmixed). Should be okay to use your nason select clearcoat over it. Since its a polyester base, should be able to clearcoat over it in reasonable amount of time, but I always like to let my base sit at least an hour before putting on clear. Last edited by kenseth17; 12-01-2009 at 07:27 PM. |
The basecoat is, well a polyester, but believe is basically a lacquer, would have to talk to a chemist on that though. Base is always the weakest part of your paint system. A urethane has to be activated to cure- dbc basecoat using activator is optional. Take a rag of lacquer thinner to dbc base without clear on it, and see what happens, even a day later. It will take it right off, heck wax and grease remover will fresh. A urethane wouldn't be phazed that easily after a day of sitting.
But I think its better to use a polyester basecoat then an enamel, all your cheap ones are enamel, omni, nason, ect. The Concept, 2021, ect clearcoats though, of course are urethane based. |
Vince Last edited by 302 Z28; 12-01-2009 at 07:59 PM. |
The PPG tech sheet TB005 for DX75 activator says it MAY be used with DBC. It must be used for tri-coat colors or applied over NCS sealer or when spraying DBC as SpectrFlame. or Flamboyance, Chrystal Pearls, Radiance II, or applying DBC as Harlequin Vince Last edited by 302 Z28; 12-01-2009 at 07:57 PM. |
PPG base/clear systems.
Base coat does not need activator, however nothing will happen if you do put it in. I've experimented with it a bit. Clear coat does require activator and I usually shoot it within 1/2 hr after spraying last base coat, as manufacturer suggests. I'd follow spec sheets to the point and you won't have a problem. I do however put more reducer in clear to lay it out smooth. |
I ordered the reducer and activator today, I will be using PPG Deltron products in the base coat. But plan to use another brand of clear, Hopefully the nason select-clear. I ordered a gallon of DT870 reducer and Dx57 activator.
The mix ratio of the Deltron is 1:1 and 5% activator. The best I can figure, I should use 6.4oz of activator per gallon, Correct? The 5% is for 1 gallon, Not the 2 gallons it makes after the mix, correct? Im now excited to see how well it sprays vs Chroma-base. Price is about the same, I have to pay a bit more for the PPG because my paint shop don't sell PPG, so I had to order it. But given my 15% discount for dupont, it is about the same in price. Anyone know for sure if I can use the nasson clear over the Deltron with activator without issues? And If I can, I need a little advice. Normally when I spray bc/cc I like to clear coat in approx 1-hour depending on the temp & weather, The Deltron says 20mins -to 24hrs. Im alittle scared to spray another brand of clear when the base is fresh. I was thinking I would let it cure out a bit before I spray the clear, maybe 3-4 hours. I figure By then with the activator, the base should be dry to the touch. And I will have less of a chance of the paint lifting, or causing a bad chemical reaction. What do you think? How long would you wait before spray a clear coat of another brand? This is why I don't ever mix paints, In my younger days I was a little cocky and thought I could spray everything. I got a hold of some cheap $30/gal ebay acrylic enamel, and used left over limco AE reducer/hardener. First 3 coats went down ok, I thought I was having an issue with my spray gun, but they leveled out OK. I waited about 25-mins to spray my 4th and final coat I got 1/2 done and ran out of mixed paint. I was out of the limco AE reducer, And used some 5-star AE reducer in its place. SO I rushed to get the paint mixed so I could finish out the 4th coat with out any dry spots. I got it finished in time, And it looked good....I went outside to smoke. & went back in the booth after about 10mins and every where I sprayed with the 5-star reducer, Had lifted up BAD. It was so bad that I could watch the blisters swell and bust.. I ended up having to strip the whole car, and spray it with a sealer and primer to get paint to stick back to it. cost me a small fortune and two extra weeks of my time. All because I wanted to save a few bucks by using left over products. I said then I would NEVER mix paint brands again! Since then I have never mixed two chemicals together at once like that, I have however sprayed single stage paints and a few days to weeks later sprayed another brand/type of clear without any issues. |
Oh I have one more question: The tech sheet does not have an Approx coverage per gallon, Approx how many sq feet does one gallon of deltron b/c cover (two gallons mixed 1:1)
thanks! Oh and anyone know anything about TCPglobel.com line of paints? Restoration shop, and Kustom shop? According to them, they offer the same type of bc/cc as the deltron. They have a cross over sheet that tells what their paint compare to, and they say theirs compares to Deltron 2000. (what I have) Their clear coat is $124/kit Not bad, But how good is it? Better or worse then the nason clear coat? |
302 Z28, thanks for supplying the correct information
Coverage depends alot on the colour itself, and how you spray. Usually 3-4 coats including a drop coat provides proper hiding, but always do a spray out card to confirm. Nothing worse than pulling it out in the sun and seeing some dark spots .2 gallons RFU should be plenty to do a complete. |
Okay, I don't know who the source is on this, supposedly someone from basf chemical (diamont paint ect), but since there was disagreement and no chemists have responded, I tried a search. And made my head spin in the process, which trying to understand chemistry does.
I swear Barry K had said even said once in the past that cab basecoats are basically a lacquer, but don't quote me on that. All DBC's propertys want to tell me it is not a urethane. Really fast dry, 50 percent solvent added and lays down flat pretty easy, activator not required, Will dry without adding an activator, affected if wiped down with solvent. Urethanes as far as I know, Do require use of an activator, and in fact will never dry without one and may not if incorrect amount is not used, would always fingerprint. No way when you wanted to sand out some trash, could you do it in about half an hour. Most painters I think would agree that the weakest part of a refinish system today is going to be the basecoat. |
| paint information | kimman | Body - Exterior | 8 | 08-10-2012 08:55 PM |
| Base coat clear coat repair problem | TimeBandit | Body - Exterior | 2 | 09-03-2008 06:22 PM |
| Base Coat / Clear Coat Qusetions | JOEPATRICK2 | Body - Exterior | 17 | 11-23-2007 01:38 PM |
| Interesting test on sanding base coat paint (against the data sheets recommendation) | MARTINSR | Body - Exterior | 208 | 03-22-2007 10:52 PM |
| "Basic of Basics" How do you properly apply filler? | Centerline | Body - Exterior | 2 | 02-10-2006 12:22 AM |
