B I N G O and bingo was his name-o!
engineczar gave you a foolproof way of checking, the one that gives you the most lift should also give you the smallest pattern and be the correct one- BUT the pattern may not be quite centered, to fix that you'll need to move the rocker stud which can be a pain in the *** and usually not worth it.
