Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help! Putting AC back into my Cutlass
Old 07-24-2012, 09:02 AM
cseay1949's Avatar
cseay1949 cseay1949 is offline
... something that may further complicate things is your wanting to run a serpentine belt .. I am pretty sure all '78-'88 G-body cars used v-belts, and the compressor was a R4 (radial 4 piston - looks like a pancake) .. you may want to get a compressor and brackets of a '89-'92 camaro or caprice .. but when you start mixing years and models the lines may end up having to be custom made .. we have done it before, take all the ends that will work, get some bulk hose and cut it to length, then match mark the clock positions of how the ends and hose align, and take it to your local parts store or tractor shop that can make ac or hydraulic lines.
Whatever you do don't re-use that drier .. not only is it probably full of moisture and debris from the system being open, but that desiccant bag inside is saturated with R12 and mineral oil residue .. it's like a grenade waiting to go off in your freshly repaired ac system!
The Following User Says Thank You to cseay1949 For This Useful Post:
zildjian4life218 (07-24-2012)
