Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help! Putting AC back into my Cutlass
Old 07-24-2012, 01:45 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
I already did this same thing to my 86 Cutlass. You will want a complete serpentine kit off a donor motor, don't try to mix and match because they vary over the years. Keep in mind you will have to swap water pumps as well as the fan for the reverse rotation of the serpentine system on the cooling components. When you get your dryer get one for a early 90's Camaro, you'll also want the lines from a camaro donor car. If you get used lines make sure you flush them good before installation. Also if you left the condensor in the car and it wasn't sealed off you'll have to replace it as well, same goes to the core.
