Help on Quadrajet Divorced Choke - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2012, 09:31 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
So I got this old truck on the cheap and am trying to fix a few things and sell it. One thing that is missing is the choke. It seems that there were Qjets made with heat risers and also some a thermostatic coil...both referred to as divorced chokes? Both attached to the intake manifold?
Attached is a pic of what I am dealing with (purple line indicates missing linkage). It appears there is a housing, or part of a housing with some missing parts and a missing linkage rod. What do I need to rebuild this? I know there are electric choke conversions but they are like $50. And like I said I want to keep costs down because I intend to sell this truck for profit.
Also the truck does not seem to fast idle. I am not sure if that is a separate issue or is directly related to the missing choke. Any help is greatly appreciated!
Name:	divorced choke.jpg
Old 05-22-2012, 10:55 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Divorced choke = choke coil mounted somewhere other than on the carb. Hot air or electric integral choke = choke coil mounted to the carb.
The divorced choke coil and housing fits where the red circle is located. I believe the secondary lock out arm is on backwards (red arrow).
The divorced choke set-up looks similar to the one below, it's a 2-barrel and details differ a bit:
Old 05-23-2012, 09:49 AM
Dang Cobalt! Yes I checked my pre-disassembly photos and that lock out arm is installed incorrectly.
So if the area you circled is for the divorced choke, then what is that "thing" on the left that I thought was the choke?
Old 05-23-2012, 03:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
When you find out, let me know!
Old 05-23-2012, 06:46 PM
Cobalt327, good description and pic. SS, you can pic up the Chevy-style coils and links at most parts stores. If not local, any resto house.
That "thing" on the left is the remnants of an EGR valve someone disabled at some point.
Jim
changing a divorced choke to a electric choke? Help please?e 71GMC Engine 1 02-11-2012 06:14 PM
Converting from external choke quadrajet to electrical choke quadrajet silentpoet Hotrodding Basics 4 10-03-2011 02:38 PM
Divorced Choke? paulh31 Engine 4 09-28-2009 06:06 AM
Rochester Divorced Choke PrimaDude Engine 3 01-08-2003 08:39 PM
quadrajet w/electric choke ace1 Engine 6 12-22-2002 01:09 PM
