help in a ram air/relocated air cleaner - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2014, 09:29 AM
59 wagon man's Avatar
looking to update my wagon a little bit and i am in need of some ideas. i am looking to relocate the air cleaner from the front of the throttle body to the drivers front rad support area . anyone have some good pics i can see thanks
ID:	111810   Click image for larger version
ID:	111818   Click image for larger version
Old 01-08-2014, 10:40 AM
Speedshift_Sam's Avatar
Mekanicus Automotive Group
Cheers! Another '59!
If it were me, I would build a litte scoop in one of the inlets above the headlights, to force air through a cone filter. In my '59 Belair, I plan to use both sides to feed a ram air box ontop of an offenhauser 3x2bbl intake. I could make you up a sketch if you like on what I have in mind for yours.
Last edited by Speedshift_Sam; 01-08-2014 at 10:53 AM. Reason: To Err is Huma.n...
Old 01-08-2014, 09:50 PM
Northstar T's Avatar
Gone sailing
niiiice looking ramjet there. when I did my L-98 I couldn't find a similar item, and I wanted one, so I ended up building one out of fiberglass myself. you'll have a lot more room to work than I had in my Vette, so maybe a Firebird TPI S tube would work for you?
love the 59s also
Old 01-09-2014, 05:46 AM
astroracer's Avatar
Spectre has ALL kinds of stuff to do this. This is the set up I have on my truck.
And I am currently putting this on the 509 in my Astro build.
Summit and Jegs both carry Spectre and you will find a lot of stuff on eBay also.
Mark
Old 01-09-2014, 08:57 AM
I have an 87 TPI firebird. I made a intake tube from some stainless and a silicone sleeve, putting the cone filter in the factory location. The only changes I noticed was how much louder it was, and how hot the stainless got. I don't think there was any gain in power over the stainless setup with the bone stock motor. They used the same intake tract with the 305 or 350 powered TPI F-birds
The Firebird inlet has a "airbox" that is mostly to quiet things down. If you're crafty, you can copy the design, minus the airbox, or for a test fit, cut the airbox off and cover the hole with a plate and some epoxy. 1986-1992 are the years you're looking for
Holley Hi-Tek Air Cleaner VS Spectre Dual Cold Air Intake the82elco Engine 1 12-13-2012 03:38 PM
Cold Air vs Ram Air 83SILVRADO Engine 180 05-26-2009 08:59 AM
Holley Stealth Ram Air Cleaner jesimonson Engine 1 10-28-2008 06:38 AM
Looking for a ram air cleaner xxllmm4 Engine 6 12-22-2006 05:05 PM
