help with rear ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2008, 11:29 PM
71corvette's Avatar
the car is a 1956 Bel Air original V8 powerglide car and should have a 3.55 rear gear. when I turn the tire one revolution the yoke only makes 1 3/4 turns. shouldn't it make 3 1/2 turns for a 3.55 ratio?
Old 06-03-2008, 04:02 AM
SSedan64's Avatar
Try it this way. Mark the driveshaft with chalk and the tire. Turn the driveshaft 1 revolution and count the tire revs.
Old 06-03-2008, 05:40 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
The correct way on a non-posi rear is to turn the wheel 2 exact turns while the other tire is not moving.
So, 2 X 1.75 = 3.50 ratio.
If it was a posi, then just one turn of the wheel(s)
Old 06-03-2008, 06:11 AM
71corvette's Avatar
thanks, I thought something was not right here
Way to check the rear end gear ratio........... Trans Am Tony Suspension - Brakes - Steering 4 06-19-2007 09:25 AM
Does anyone know this rear end ratio? camaro freak Transmission - Rearend 2 06-01-2007 11:45 AM
VIN # and rear end gear ratio olds79 Transmission - Rearend 1 11-24-2005 09:17 PM
59 vette rear end ratio? 1oldie Introduce Yourself 1 11-09-2004 11:19 AM
What is the gear ratio for a GM rear end? jpd37 Transmission - Rearend 6 02-23-2004 01:52 PM
