My rear wheels are frozen on....I need to check and adjust the rear drums on my 79 Chevy k10. I cannot get the wheels off. I spreayed them with PB rust blaster and tried putting a torch on the wheel until it turned red. I even put a jack between the leaf spring and the rim and still nothing. Any suggestions?
NH, home of snow, slush, salt on roads, and stuck wheels.
The center of the axle that sticks into the wheel centering hole is rusted to the wheel. This can be a bear to get free. You have used PB blaster, good. Unfortunately heating the wheel made the wheel grip the axle even tighter.
Do the PB blaster thing again, spraying from the top to allow the blaster to seep down between the brake drum and wheel and axle flange.
Wait a time for it to penetrate then jack up the vehicle and block solidly, leaving the wheel hanging free. Take as large a hammer as you can safely use and , after laying a length of 2X4 or 2X6 across the wheel in back, give it a good shot from the rear, spin, smack, spin, smack, and then pop the front in a place or two and go to the back again.
I live just under you...literally feet from the NH state line in Massachusetts..... I've had this same problem soooo so many times.... oddly it seems to ALWAYS be only on mid 70's-80's Chevy and GMC trucks and older Caddys. ( which all take the same rims... maybe it's something with them stock steel rims???? dunno)
Anyhow, the above posters advice is about the best... get a big sledge and give some really HEALTHY swings to the tire. And even then this doesn't always work.... to which I can recommend...loosen all the lug nuts, remove all but 3 across from each other... leave the remaining 3 lug nuts about 2 turns loose from rim.......yep you guessed it..... now drive it around the yard a bit.
PLEASE stay in your yard or driveway... don't get crazy.. keep it under 85 MPH... actually a few yards back and forth will do it wonders.... when changing directions do it as abruptly as you can... it's the impact you will need to break the rim loose.........I don't even bother swinging on the with a sledge any more... I just drive it around some with lug nuts loosened... saves missing and smashing a rim too....or the sledge bouncing off at the wrong angle into your shin.
When you get them off, be sure to slobber a liberal amount of "Never-Seize" on the hub before re-installing, that will last through our salty winters..
thanks....I'm going to try driving it back and forth in the yard (maybe in low) to see if I can get it loose that way. I was thinking of then sanding the priming the wheek and drum (along with the anti seiz) with hopes to prevent this in the future.
I had the same problems with the rear wheels on my 87 Suburban. After trying the sanding and painting and grease on the surfaces I eventually cut a piece of tractor tire tube to size with holes for the wheel studs and placed it between the wheel and brake drum. That worked the first time I needed to remove the wheels. Haven't removed them for two or three years now as I have retired the sub. I will be stripping it out this spring for the tranny and whatever else I can salvage to be used in the future or sold for cash.
I think I'd skip the paint... I'm probably sure that would just end up acting as a glue in the long run. Clean and sand then probably just oil it and never-seize the crap out of it... the never seize won't allow ANY rust to form, the never-seize will adhere and stay in place better on bare metal too.
Gotta love New England!..... just looked at the weather for X-Mas.... 49 and cloudy.......one of the only benefits of living here is a white Christmas..... now it's gonna be near 50...I WANT SNOW!
hi,i had the same problem with a toyota pickup.i did everything possible,heat,beat and this went on for 2 full days. and the 2 bolt holes to remove the drum stripped out .i finally said b.s. ,i got a drill with a 1/8 inch bit and started drilling holes around where the drum and axle come together. i dont know how many holes i finally drilled,but it was a bunch,the drum came off,and i had to go to u=pick=it and get another drum....have fun..im boatbob2
take a die grinder and increase the clearance between the center of wheel and axle, do it on the wheel. just a couple of thousands, .002 will be enough.works for me.
I always drive around with loose nuts...but thats a different topic.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
