Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help on recent 383 rebuild burning oil
Old 09-14-2008, 11:36 PM
SDLuck SDLuck is offline
oil burning
I am thinking this is a small block chevy? This is a common problem that happens with some intakes and gasket not being matched properly.If the block has been decked or the wrong port gasket used ,there will be a vacuum leak in the valley and oil will be sucked into the intake and coat the spark plugs much like bad valve guides. Pull intake and see if the cylinder head ports are oily.
