Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help - Recreating Fan Wiring Diagram Using Derale Controller & GM Stock System
Old 07-01-2012, 09:57 AM
2x4 Barrels 2x4 Barrels is offline
try this
Hi Fcastro
I think I see the problem.You are breaking ground to control unit.Sorry this is a big no,no .Your temp sensor may be backfeeding a ground to the control and possibly causing damage.I would put that swtich in the power feed circut.Center post feed power,post1 control unit,post2 control unit and green wire.Then add a wire from ac cluch + to post2.Then you dont need a relay.
2x4s
