Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help - Recreating Fan Wiring Diagram Using Derale Controller & GM Stock System
Old 07-08-2012, 06:39 PM
LATECH's Avatar
LATECH LATECH is offline
Last journal entry: GTO Reproduction Hood
If you wire the derale ground circuit to the OE relay coil ground as I described, it will prolong the life of the controller.
If you dont have the same setup as the OP just add a relay for the fan circuit, prefferably a 40 amp bosch, and use the derale controller relay to activate the bosch relay COIL, that way the derale control will last as it is only handling a small amount of current to run the Bosch relay which is handling the Load. And the bosch job is dispensable, or at least more so as it is quite a bit cheaper than the derale unit.
Fact is stranger than Fiction
