Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help - Recreating Fan Wiring Diagram Using Derale Controller & GM Stock System
Old 07-08-2012, 08:27 PM
cucumber1949's Avatar
cucumber1949 cucumber1949 is offline
T-Bucket, Corvette, Mustang
Originally Posted by LATECH View Post
If you wire the derale ground circuit to the OE relay coil ground as I described, it will prolong the life of the controller.
If you dont have the same setup as the OP just add a relay for the fan circuit, prefferably a 40 amp bosch, and use the derale controller relay to activate the bosch relay COIL, that way the derale control will last as it is only handling a small amount of current to run the Bosch relay which is handling the Load. And the bosch job is dispensable, or at least more so as it is quite a bit cheaper than the derale unit.
Now that's a reasonable idea. Just might have the controller relay trigger a pair of relays in parallel to help prolong the life of the secondary circuit and provide a backup. Might be a bit of overkill, but I hate it when you see the temp a little above normal and realize your fan won't come on.
Thanks for the suggestion.
