Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help?Redid my Mustang Fastback roof (with filler). This is where I always get stuck!
Old 07-26-2011, 07:01 AM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
As dbm said now go with the poly putty and block sand with a long hand broad and sand toward center but at a slight angle. I've also used sprayable poly primer at this point. Just be sure to put on a little more that normal so you have enough to block sand. then go with 2-k primer.
