Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help?Redid my Mustang Fastback roof (with filler). This is where I always get stuck!
Old 07-26-2011, 10:09 AM
ogre's Avatar
ogre ogre is offline
the 'Duracell Project'
one thing to mention: once you hit metal you really need to apply more filler or you risk getting a low spot. if you sanded with 40 and change to 80 now, you will get low spots. that's why dbm says to go with more filler (if i read him right). get it right before you apply primer will save you a bunch of work block sanding the primer.
