Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help?Redid my Mustang Fastback roof (with filler). This is where I always get stuck!
Old 07-26-2011, 12:16 PM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
Just fill your low spots along the edge with more filler going out far enough to make it easy to work filler and block sand down as best you can. Then I would coat the whole side with poly putty and hand board down with 80 grit.And then go with your 2-k primer or a good coat of sprayable poly primer.Do not tap down high spots unless there's something that's way to high. Sometimes it can mess thinks up.
