Help Removing Pinion Yoke - GM 10-Bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2006, 07:35 AM
72NOVA454
Ok, I finally got the pinion nut off. Big deal right?
Anyway, now I can't get the yoke off. It's basically just "stuck" on there. Been there since 1972. I tried hammering the pinion shaft inward to break it loose from the yoke. No luck. I don't want to damage it or the threads.
How about using a puller? That would probably work, but are there pullers for pulling yoke's? I've used lots of pullers but never seen one for a yoke.
any suggestions.
thanks.
Lee
Old 11-10-2006, 07:51 AM
DV8's Avatar
DV8 DV8 is offline
Sloe Lurner
Last journal entry: front boxing plates
2 jaw puller
try a 2 jaw puller. you can borrow them from autozone or advance auto. Youll probabally need to get one wit hlonger arms, Its not good to beat on the pinion too much.
Mike
Old 11-10-2006, 08:12 AM
aka Duke of URL
Use a harmonic balancer (two hole) puller. DO NOT beat on the flange.
gm 10 bolt CHEVELLE12345 Transmission - Rearend 5 07-20-2004 03:08 PM
gm 10 bolt rearends redchevyhotrodder2 Transmission - Rearend 4 07-19-2004 11:55 AM
10 bolt or 12 bolt rearends ? a62chevy Transmission - Rearend 5 09-21-2003 05:16 AM
gm 10 bolt axle, bearings. hepcat Transmission - Rearend 4 09-20-2003 08:36 AM
7.5" gm 10 bolt????? Vancouver Grand Prix Transmission - Rearend 6 05-27-2003 03:49 PM
