Help Replacing Bed Side - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-23-2011, 09:00 AM
You might try using some 1200 & 1500 dry with an interfce pad on your da and knock the peel down, then buff. You may be able to nearly match the factory peel.
It's worked for me
  #17 (permalink)
Old 06-23-2011, 02:47 PM
Called SPI and told them the situation and they recommneded getting some 600 & 800 and wet sanding the panel. Then reshoot the clear.
Going to pick up some on the way home. Any recommendations for a block? The bedside has all of the those different shapes/ridges on it so that makes choosing the block a little more difficult. I'm going to ask the parts store and see what they say but any suggestions would be greatly appreciated.
  #18 (permalink)
Old 06-25-2011, 06:48 AM
Wet sanded with 800 and followed up with 1500. Cleaned and then shoot the clear again it looks a lot better overall. I did manage to get a line of runs on the lower side, I plan to cut and buff to clean it up but do I need to wet sand then clear again to get the runs out?
  #19 (permalink)
Old 06-25-2011, 06:25 PM
On my numerous runs I just wait a couple of days then shave them down, block them smooth and buff.
  #20 (permalink)
Old 06-25-2011, 06:57 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Runs, just means, you got 'nuff paint on. Nice job, good pictures. Show us one when you got it buffed out and sitting in the sun.
  #21 (permalink)
Old 07-05-2011, 06:25 AM
Got the clear done. The 2nd round went much better but still had alot to do. Had to have a little help with the cut and buff from the FIL (used to own a shop doing body work). Long story short he hit it 1500 then 3000 on a orbital and then cut/buffed and it turned out pretty good. Had some peel in it but so did the factory. Matches well in my opinion.
I also put a U-Pol Raptor bed liner on it while I had the box off the truck. Put the pics of that up as well.
Overall I'm really happy with it and feel a lot more comfortable doing this when I move onto the 71. Thank you again for everyone's help - I really appreciate it.
ID:	56570   Click image for larger version
ID:	56571   Click image for larger version
ID:	56572   Click image for larger version
ID:	56573   Click image for larger version
  #22 (permalink)
Old 07-05-2011, 06:32 AM
Here are the pics of the Bed Liner - Went on really easy and the kit was only ~ $100. We'll see how it holds up to abuse over the next few years. It will be hiding on a tonneau cover so it shouldn't fade. Again Thank you very one for the help.
ID:	56575   Click image for larger version
replacing the side windows on a 1960 pick up crusin60s Body - Exterior 2 03-29-2011 01:15 PM
Passenger side dip vs driver side dip in early Nova dirtinla Engine 1 11-20-2008 12:45 PM
Weird problem, rear moves side to side?? Nova_63 Hotrodding Basics 5 09-07-2008 08:47 PM
roller rocker tips off center from side to side awoodman Engine 8 11-17-2007 08:25 AM
How much side to side movement does a rear axle make STATUTORY GRAPE Suspension - Brakes - Steering 9 11-23-2004 06:23 PM
