help with the right spark plug to run.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2012, 12:12 AM
Built a mild street /strip weekend type car(nova)..
Motor is a mild built 350 with some mid 90's Alum heads(angle plug)..
I guess I'm curious on your guys input and what u guys would run.
"at work and bored its 1am , can't stop thinking about fireing the car up"LOL
Thanks for all your input..
Old 07-27-2012, 08:19 PM
bigdog7373's Avatar
Of course it's fast
If youre asking about brands, I've only ever used ac delco, ngk, and autolite and never had any problems
Old 07-27-2012, 08:33 PM
LATECH's Avatar
I would put in an R45T AC delco. From there , read the plugs after you make a pass with it. Adjust the heat range accordingly.
An R46T is one step hotter
An R44T is one step colder
The "T" in the plug designation denotes a taper seat, meaning the area that the plug makes its seal is the taper edge at the top of the threads (next to the plug body). Look at the heads to be sure they are made for taper seats. They very well could be a washer seal type of plug. In which case you would drop the "T" suffix from the plug number - R45 for instance. LA
Fact is stranger than Fiction
350, spark plugs
89 5.0 H.O. spark plug wireing/spark order psikpa Modern Electronic Engines 6 05-11-2012 09:01 PM
Spark plug wires jumping spark STATUTORY GRAPE Engine 4 10-04-2009 06:14 AM
What spark plug should I run??? Ratoflic Engine 6 05-25-2008 09:18 PM
what plug to run? ck customs Engine 1 05-24-2008 09:14 PM
What plug should I run oregon chevelle Engine 6 08-25-2005 01:43 AM
