help rough hp estimate
hi all,im Adam from Australia.Heres my question,could someone please help and let me no roughly the hp and toque figures on my motor, I'm nearly finished and will the combo work ok cheers ads385
350 010 4bolt 3.750 stroke 4,040 flattop 5cc pistons .005 above deck with 65cc afr 210 street eliminator heads 256/252@50 650 lift solid rollercam 4&7 swap 108 850 mechanical carb holley choke tower milled off vic jnr manifold portmatched to heads full ignition rev limiter etcc,msd 1.5 ratio roller rocker arp head bolts,arp bottom studs ,with windage & scraper sump oil galleries relieved tunnels aligned,deck squared all balanced rotating *** forged hbeam rods ,only hypatec speed pro piston and steel crank.thanks hope will work I'm only new to engines thanks i hope to hear back from u all soon . sorry it will be a t400 trans with either 4500 or 5000 stall converter with 3.9 or 4.11 gears in a kings wood ute thanks again,
in my opinion
your motor is going to blow up in your face.
cast pistons? your pistons coming out of the hole is scarey. .005 out of the hole plus .003 bearing clearance plus .007 piston rock =.015 out of the hole with a stock .043 gasket your going to be .025 too close on piston to head clearance your cast piston is going to whack into the head porting oil channels with a solid roller is counter productive your going to have to install oil restrictors or you going to suck your oil pan dry |
| another hp estimate... | elsky79 | Hotrodding Basics | 15 | 07-16-2008 05:30 AM |
| Estimate | EastCoastSBC | Engine | 1 | 10-01-2006 05:28 PM |
| 1/4 ET estimate | 66novaht | Engine | 26 | 01-27-2006 07:53 AM |
| rough estimate please | Aces0vr8s | Body - Exterior | 4 | 06-06-2004 08:47 AM |
| Can someone give me a rough Dyno estimate? | leastbay | Hotrodding Basics | 8 | 06-03-2004 12:41 PM |
