Help Runs in paint? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2009, 03:46 PM
Help Runs in paint?
Hello I finally got around to getting my guns cleaned properly and spraying. I used my new gun today which recommended a higher pressure 50psi and consequently I got a few runs on the first coat. I sprayed dupont centari single stage acrylic enamel.
-I need to know how long do I have to wait before I can sand it smooth and repaint over the runs?
-Here is the tech sheet if that helps. I couldn't find the answer on here but I am new at this so it may be there.
http://pc.dupont.com/dpc/en/US/html/...et/centari.pdf
Old 11-08-2009, 12:28 PM
Centari w/hardener wait a minimum of 72 hours, preferably a full week in a heated shop. Without hardener, strip it off now and start over. Centari without hardener will craze when repainted, even a year later.
Good luck with it.
Painting a Metallic in pieces Polish Painter Body - Exterior 18 09-11-2010 06:16 AM
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-21-2007 11:32 PM
what color to paint? jum Body - Exterior 14 07-30-2006 12:29 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
