Help S-10 frame swap to a '49 Chevy PU
I need to know what route to take in a S-10 frame swap to a '49 Chevy PU? I have found kits, high price ... so I was just interested in some other cheaper ways. Any help would be great.
Going to give it a try ...
the only thing I'm not sure of is the distance from the front. I guess that putting the cab on it and going from there is worth a try? I was just hoping that someone could give me some ideas or problems they ran into when starting this. Well all it is a time of course and we all have plenty of that, unless the wife and kids find me.
There are some real good build threads on the HAMB covering the AD on S10 frame.
HAMB ... I will do a search on that.
thanks for the input. I will do a search on that. I will let you know what I find.
My 48 is on an s-10.
First I cut off all of the stock S-10 mounts. Then I sat the cab with the front cap installed onto the frame. I placed wooden blocks between the cab and the frame for mock-up. I centered the wheels in the front fender openings (I had a couple hundred pounds of metal piled on the front crossmember to simulate drivetrain weight) and then went for side to side centering. Once I was happy with the look. I made mounts that fit from the frame to where they needed to go on the body. Oh yeah, I used jeep cj5 style body mount rubbers. If I was doing it again, I would set the body higher and lower the suspension more...more room for a radiator. Here is my build thread. My rusty/ratty 48 chevy truck build (w/ pics) |
bolt on or weld, with ez instructions a cave man can do it! the trick is to get the right s-10 has to be a regular cab long bed for a one day swap a ex cab can be used but you need some fab skills and a welder to split the frame the frame and take 5" out of center 2 much work good luck. 48 S10 |
| 1950 truck frame swap to 1980's chevy frame | 1950truck | Suspension - Brakes - Steering | 25 | 01-24-2013 06:13 PM |
| Help with 55 Chevy frame swap | Bowtiez84 | Hotrodding Basics | 0 | 02-04-2011 02:46 PM |
| 40-41 chevy frame swap | 40-41chevycoupe | Hotrodding Basics | 14 | 09-18-2009 03:51 PM |
| 37 chevy frame swap | novanut | Hotrodders' Lounge | 2 | 02-22-2009 09:27 AM |
| 49 chevy p/u frame swap | krazytrain | Suspension - Brakes - Steering | 6 | 06-22-2007 12:51 AM |
