I am not an expert (they will be along, I am certain), but that looks like a form of corrosion to me. Sometimes the steel "blackens" instead of the usual orangish rust (or is a mix of both).
Im guessing you will need some kind of rust neutralizer/converter before painting, but please wait for others to chime in. |
You need to get a D/A sander and some 80 grit discs to get through that stuff . It'll go much faster than what you've been using also. Trust me . I stripped a '52 Mercedes back in '85 with a D/A sander . It didn't take all that long, and it had several coats of paint .
If you put some phosphoric acid on there, it will loosen up any loose paint and it will remove the surface rust if there is any. Leave it on there for awhile and you can rinse it off with water. You can put the epoxy primer on after.
I have a small 6" D/A sander but its broke. I have some week Hydrochloric acid but I think it will actually eat the metal itself, so I dont think I want to go that route.
Phosphoric acid before and after.
I found some of that Klean strip acid etch at homedepot http://www.homedepot.com/Paint-Clean...atalogId=10053
its only $15 but not sure if chemical is the way to go. I do have a homedepot near me so if this is what needs to be done then this is what I may have to do. I actually took vacation from 1 job so I can get this done before the snow and cold gets here so its almost a must. |
They sell it under a few different names. The stuff I use is green. It works, I have already done it and the paint has been on for years. It says you can use body filler over it also. It kills any surface rust. It takes a while for any rust to reapear when it's left out in the elements without any primer put over it.
This is a frame before and after. It was only on there less than 2 hours. I had it rained on and it did not rust. It will get surface rust on again if left unprimed but it takes awhile.
I guess my only concern with the klean strip prep/etch is, will it take off the black? I believe that may be an old rust converter as it looks to have brush marks in it, but whatever it is, the Aircraft stripper wouldnt even touch it and that stuff is strong. I used it once to take undercoating off and old gas tank that was covered with the stuff, it ate through it with no problems.
I pour it in a jar and brush it on with a paint brush.
Its hard to tell but it could be a few things..it would help to know how old the car is...
You should try the stripper again in a small spot, put a thick coat on ,pour it out of the can and make a little puddle about the size of a soft ball, let it sit 30 min,then scrape it off with a razor scraper ,it might come off clean. It could also be old lacquer primer ,in a very (small pitted ) (sandpaper) like surface that your not getting deep enough into ,sometimes a wire brush or wheel works with the stripper try the same thing to see if it softens it enough to get it off with a razor scraper,the razor is the key and you'll need a whole box of them... as far as the acid goes use only phosphoric,be careful and pay attention to what your doing ...I prefer Ospho because it doesnt need to be neutralized.everything you need to know (pros and cons) about it is on a thread called "the Ospho solution" complete with videos and step by step proceedures... ...Heres a couple short vids on stripping (paint stripping ) http://www.streetfire.net/video/chem...xy_2053679.htm http://www.streetfire.net/video/usin...-2_2050902.htm Last edited by deadbodyman; 09-20-2010 at 04:24 PM. |
The decklid in the picture has lacquer paint on it. I brushed it on right over the top. I have left some of it on other stuff without rinsing it off with water. It becomes sticky after it's on a few days without rinsing it off. I leave it on overnight when there is lacquer paint on the car. It will loosen some of the lacquer paint. The factory primer is some tuff stuff, it does not seem to do much to that.
| Finally(after 2 years in primer) blocking the high build, going to send her for paint | Ripped | Body - Exterior | 2 | 08-10-2010 08:16 PM |
| Roof Cutting/Grafting Options | sparkydog | Body - Exterior | 7 | 12-28-2009 08:54 AM |
| Took sun roof out of 84 Cutlass cross members missing will roof rattle at high speed? | heathj1 | Body - Exterior | 9 | 04-16-2009 07:28 AM |
| good primer over ok primer | hoss | Body - Exterior | 1 | 09-17-2003 01:28 AM |
| Quickie primer question | Bluepen | Body - Exterior | 1 | 05-21-2003 05:33 PM |
