Help on sanding out runs in enamel - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2010, 07:27 PM
K and K's Avatar
Last journal entry: Original 365
Hey, I just sprayed some POR-15 engine enamel that I didnt reduce enough with its solvent and it went on pretty thick. It ran as it dried on the valve covers. What would you use to sand and buff these runs out?
Old 09-22-2010, 11:02 PM
Niko1080's Avatar
I would sand out the runs and re spray. It's easier in the end.
minor ? - wet sanding vs color sanding cboy Body - Exterior 33 10-06-2012 06:35 AM
Color sanding Help coupe33 Body - Exterior 7 12-19-2007 05:47 AM
Why does acryllic enamel seem to spray and flow better than BC/CC STATUTORY GRAPE Body - Exterior 4 04-11-2006 06:29 PM
acrylic enamel vrs urethane americanLT1 Body - Exterior 4 09-15-2005 10:23 AM
acrylic enamel base then acrylic enamel cc swoodard23 Body - Exterior 12 07-30-2005 06:19 PM
