help with satll convereter - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2002, 07:14 AM
Post help with satll convereter
I bought a th400 with a stall converter in it. I will be placing it in my 72 z28 , but i want to know if i would need a new converter? ( its stock)
It will be going into a 454 eng. I took the trany to the shop to have it checked out . They said it woul need re-seals, cluthes, and i wanted a shiftkit in it . All for $350 .is this alot ?
please help..Oh and what is the differece between the 350 & 400 turbo ?
thanks 4 ur help
Old 12-13-2002, 08:31 AM
Post
Here locally I can get a COMPLETE rebuild for about $300, so I would say that sounds a bit high....
Old 12-13-2002, 08:43 AM
Post
A 2500 or so stall is good in a performance street car. The used stock ones are always too low of a stall rating.
A turbo 400 has a 1st gear of 2.48 to 1
A turbo 350 has a 1st gear of 2.52 to 1
The Turbo 400 is a heavy duty automatic and the 350 is more medium duty. The Turbo 400 is larger, heavier and uses a different slip yoke.
When Chevrolet released the 1970 Chevelle with the 454 450 Horsepower engine.... the only automatic available was the Turbo 400. :p :p
[ December 13, 2002: Message edited by: Deuce Roadster ]</p>
Old 12-14-2002, 03:31 PM
Post
summit has converters 2800 stall which i have tried and think you would be happy with its difference in performance for only like a 110.00 dollars.
