Help with SBC Distributor wire? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2012, 07:59 PM
Ok, I am sure this is simple, but I don't know. Trying to replace a wire from my distributor to the carb, the wire just fell out of the distributor connections! So, please help me figure out where it went. I "think" maybe from the left/front connector, not the one with the larger orange wire, but...? Thanks in advance.
ID:	63672   Click image for larger version
ID:	63673   Click image for larger version
ID:	63674   Click image for larger version
Old 03-03-2012, 08:27 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Are you asking about the black wire from your choke? It is common to mount it to the top of the carb, or to a nut on the carb base.
Old 03-03-2012, 09:41 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
The red wire should go to a source that will supply power to the choke when the key is in the 'on' position only. The pink wire from the IGN switch at the base of the steering column is usually a good source, as it has a full 12 volts.
The pink wire will go to the + terminal on the HEI distributor. The brown tach wire is not a good source. Some people have even used the green wire to the TEMP sending unit. I like the big fat 12 gauge wire to the HEI, that sometimes looks orange because of age.
Old 03-03-2012, 10:57 PM
Thanks. So, is that the orangish wire on the right hand clip that's probably 10-12Ga?
mallory distributor how do you wire this thing rick39452 Engine 1 08-03-2010 08:52 PM
hei distributor coil wire bigvan98 Electrical 1 06-20-2007 10:57 PM
Wire Diagram for points,starter,1 wire alt,and distributor plainhavoc Electrical 3 04-12-2006 03:13 AM
how do I wire this distributor? gmwillys Electrical 17 01-01-2006 12:16 AM
Distributor wire Mertz Engine 8 05-23-2003 08:17 PM
