Help Selecting Clutch Master Cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2011, 09:46 PM
Im transplanting a 327 and Muncie into my 62 Studebaker Lark. Im going to use a hydraulic clutch (Novak) conversion. They supply the slave cylinder etc on the clutch end. They recommend matching the master cylinder bore to the slave cylinder bore (either 3/4" or 7/8"). When selecting a master cylinder I'm seeing some universal ones but also have worked on Triumphs (the British car) and the TR6 clutch master cylinder looks like it will fit well and is reasonable ($56). Is there anything else to consider besides the bore size? Thanks.
Old 09-27-2011, 10:28 PM
BOBCRMAN@aol.com's Avatar
Try a GM clutch master from mid ninety 1500 series truck.
Clutch master cylinder G-Body T5 swap greenmoonshine Transmission - Rearend 4 05-07-2010 06:37 PM
Clutch master cylinder chevy7283 Transmission - Rearend 1 07-13-2009 04:04 PM
Clutch Master Cylinder chevelle_502 Suspension - Brakes - Steering 4 07-16-2007 06:32 AM
Clutch Master Cylinder for a T56 BadA$$37 Transmission - Rearend 3 11-03-2006 08:00 PM
clutch/master cylinder elkay65 Transmission - Rearend 8 10-30-2004 11:02 AM
