Help with setting timing Big Block Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2008, 08:26 PM
71 nova's Avatar
I have a 454 Big Block Chevy with a mild street cam, headers,intake,MSD 6AL and a MSD distributor and stall converter etc... Since this is different that stock what should I set the timing at ? Better yet what steps are involved to set the timing ?
Thanks in advance
Old 08-02-2008, 09:29 PM
Guy Hiltz's Avatar
The best way is to set by useing total timing,all in by 3000 RPM.A good ballpark figure is between 36-38 BTDC total timing.You will need a marked balancer,a timing tape or a dial back timing light.Dont worry too much about initial timing,this doesent matter a whole lot with a performance build.Un hook the vaccuum advance when you do this,
Guy
Old 08-03-2008, 11:41 AM
71 nova's Avatar
Guy
Thanks guy
Old 08-03-2008, 02:19 PM
Guy Hiltz's Avatar
Youre welcome,I hope this helps !!!
Guy
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 03:36 PM
468 Big Block Chevy Guy Hiltz Engine 35 05-24-2008 01:17 PM
Big block water pump on small block! TVR383 Engine 14 04-15-2008 07:43 AM
Big Block Chevy ... How much does a block weigh Rob Keller Hotrodders' Lounge 5 03-24-2008 06:10 PM
4 bbl on big and small block Chevy Quick 58 Engine 1 11-21-2007 04:40 PM
