Help on setting timing sbc suggestions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2013, 04:56 PM
Hello guys I just got my truck back the other day and everything is running well on my 350 sbc with new aluminum heads but I have a quick question and need some ideas. My timing tab is the most common 2 oclock spot and matches my balancer fine but I changed out my power steering pump factory bracket with a new aluminum aftermarket bracket and the bracket goes out in front of the water pump and its hard for me to really get my timing light to flash on my balancer reall well to set my timing. My balancer is black and has timing degree markings on it and I put a white mark of paint across 16 degrees btdc but without being able to get my light to flash on it good enough I cant really tell where its at. I can just faintly see the mark but cant see anything else to see what advance is etc. Any suggestions or ideas?
Thanks
Eric
Old 04-06-2013, 08:06 PM
vinniekq2's Avatar
extend the paint to your pulleys or something you can see
Old 04-06-2013, 08:16 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I've killed about a million brain cells just thinking about this. If my T wasn't torn down I'd try it, but thinking outside the box, could a person time it off of #6, marking the damper on the opposite side with a #6 TDC mark or timing tape? Or have I got way too many neurons running around inside my head?
Semper Fi
Old 04-06-2013, 08:20 PM
vinniekq2's Avatar
#6
why would you use #6?
Old 04-06-2013, 08:32 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Thinking it's phased 180* away from #1, and it might give some idea of what total timing advance is for instance, with a dial back light or a timing tape applied 180 degrees from TDC on the damper. I'm probably thinking way too far out of the box with this idea, it's been a long day.
Semper Fi
Old 04-07-2013, 10:35 AM
Hello thanks for the tip I will put lines on my pulley and see if that helps. I can kind of see it but without the light angle right on it and things are going so fast at 900rpm idle its kind of a faint mark but I get really close and get initial just fine but I still want to see my advance and change accordingly. Thanks for the help.
Old 04-07-2013, 12:25 PM
The white mark needs to be on the balancer TDC mark.
Old 04-08-2013, 06:23 AM
You can set the initial advance using #1 or #6, whichever is most convenient. I use #6 because it is easier to hook up the timing light on the passenger side of the engine using the 12V lug on the back of the alternator for the power supply. Using #6, I don't have to lay the timing light cables over the engine and risk getting them caught in the fan.
If you have a 0 to 360 degree timing tape on the damper, or the damper is marked off at least 0 to 90 degrees, set the initial timing advance at 12 - 13 degrees with the engine idling no more than 800 RPM, with the vacuum advance source on the engine plugged. The idle should be no higher than 800 RPM in order to set the initial timing advance because the mechanical (centrifugal) advance starts advancing the timing about 900 RPM or sometimes as high as 1100 RPM on some distributors that are designed to be used with a radical camshaft. That will be the true indication of the initial timing advance, without centrifugal or vacuum advance. Set the INITIAL advance at 12 - 13 degrees, then hook up the vacuum advance and the INTERMEDIATE timing advance will bump up to 22-25 degrees, then spin the engine to 2500 RPM and the TOTAL advance will stop at 34 -35 degrees. .
Since most people have a radical camshaft (long duration-low vacuum) in their engines, it is difficult or impossible to determine the initial advance. The only way we could determine TDC and the initial advance on our 355 CI SBC powered Jr. Fuel dragster was to use a buzzer attached to the Joe Hunt Scintilla magneto.
Old 04-08-2013, 07:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
Eric
I would mount a rigid pointer somewhere where it can be easily seen w/the timing light, then set the engine to TDC using the existing tab and damper line. Then use a timing tape, aligning the new pointer w/TDC on the tape.
More at Make a timing tape.
Old 04-08-2013, 08:35 AM
Hello guys here is an update. It was not as bright out yesterday and I got my timing light back out and after trying different angles I was able to get my light to shine just at the right angle to set my timing with the marks painted different colors for tdc and initial timing and vacuum advance and mechanical timing. My balancer has markings for 0 to 50 degrees and the 180 markings as well but they are not colored and I painted the balancer black so it would not rust. So I have to put paint markings on what I am looking for to get it set. I got it all set up with initial, mechanical and vacuum advance set just right. Thanks guys for the input appreciate it.
SBC Timing chain suggestions 84TA406 Engine 3 08-04-2009 08:28 AM
setting timing on 350 sbc elcaminodragster Engine 4 01-05-2009 08:59 AM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
setting the timing schettler Electrical 3 10-18-2003 10:13 PM
Best Timing setting SBC? Dave E Shank Engine 3 12-17-2002 06:13 PM
