Help in Setting valves on a 383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2012, 04:22 PM
I had to remove the heads on my chevy stroker. I replaced one of the heads with a new one. How can I set the valves without running the engine? I don't want the oil mess associated with running while adjusting. I was told there is a way to do it without starting the engine.
Thanks, Jeramiah
Old 08-07-2012, 08:02 PM
vinniekq2's Avatar
do you have a degree wheel on your engine?are you good at math? NOTE: there are valve covers that have sides but no top,this stops some of the oil splash for making adjustments on a running engine.
Old 08-07-2012, 09:50 PM
I have been using this method for years. Read this entire article it has the info for adjusting valve lash cold on any type cam. The website is: Adjusting Valve Lash. I printed a copy of the procedure to have next to me as I adjusted the valve lash.
Old 08-08-2012, 06:31 AM
Thanks for the info and web site. I will print this and use it when I do the adjustments.
Thanks again, Jeramiah
setting valves solid cam ssonny34 Engine 5 10-24-2009 07:48 AM
Is this right on setting valves? savman1 Engine 4 07-09-2009 01:19 PM
Need help with setting valves chevy350cutlass Engine 7 03-03-2008 04:18 PM
setting the valves ??? savman1 Engine 13 09-09-2005 09:56 AM
setting valves boomerac11 Engine 1 04-22-2003 01:02 PM
