Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help with smoke
Thread: help with smoke
Old 01-25-2005, 08:08 PM
RdNckMike RdNckMike is offline
help with smoke
I bought a early 80’s chev 350 out of a ¾ ton van, to have rebuilt and dropped in my k10. I had the crank turned, block 30 over w/flat tops & Hasting rings, mild cam, new lifts & push rods. Total overhaul on heads, with larger intake valves and guides. New Performer intake toped with a used edelbrock 600 that I had rebuilt, and a new Mallory hei dist. Now for the problem….it smokes and burns oil and its well past its brake in. Is it possible that my pcv valve could be pulling oil into the carb? the pcv is new and I know my edelbrock valve covers have baffles. The spark plugs also look fine and the motor runs great.
