Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help with smoke
Thread: help with smoke
Old 01-25-2005, 08:14 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Check for wrong spec PCV also check for oil leaking into intake runners from the bottom side. Common problem if heads/block have been milled excessively. Sometimes leaving the end seals out (use silicone) and using thicker intake gaskets will cure the problem.
