Help...Spark plug reading - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2004, 05:46 PM
Slant3's Avatar
84 Mutt
Last journal entry: Steering column
This particular plug came out of the #2 cyl. (see pic.) The rest of the plugs dont have this wet spot, let alone this much --what looks to be detonation on it. Whats up with this cyl.? Wet spot and a lot of piston balls surrounding it.
Old 09-17-2004, 06:09 PM
Tazz
do you have a miss?
is that why you pulled the plugs? looks clean....can't see wet?? are talking about the little balls?
Tazz
Rat Rods Rule!
Old 09-17-2004, 06:28 PM
Slant3's Avatar
84 Mutt
Yea the little balls...Is that piston Jizim?.I do have a slight miss at 3000rpm then it goes away. I had -, bad advanced timing long ago(to far advanced)..I tromped on it and had a slight -ping- so I droped the timing down and it got better. I decided to check plugs and saw this.
Old 09-17-2004, 07:26 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Are you using a gas octane booster ?
Looks like deposits to me and those can cause some problems.
You said
Do the other plugs have any deposits on them ?
What is this much ?
Luv the smell of NITRO in the morning.
Old 09-17-2004, 07:43 PM
Slant3's Avatar
84 Mutt
Yes I am using octane booster. What kind of "deposits"are these?What kind of problems does this cause? Some of the other plugs have deposits on them but not as much as the 1 in the pic.
Old 09-17-2004, 07:52 PM
1BAD80's Avatar
Wiki Edits: 2
The deposits are from the octane booster.
Stop using that brand for one thing and the deposits get hot and ignite before the spark plugs do. You should know the rest.
Old 09-17-2004, 08:05 PM
Slant3's Avatar
84 Mutt
thanks Bad80
Old 09-17-2004, 08:22 PM
docvette's Avatar
Wiki Edits: 12
Booster
Doc here
Are you using that Booster in the yellow bottle? Made by "SNAP"?
I used that stuff in the Vettes, and it made the stains too..
Go to a better brand...
BTW, the stain is Booster, the balls look like past detonation...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-17-2004, 08:37 PM
Slant3's Avatar
84 Mutt
Its new Prestone 0 to 60 in an orange bottle. What do you mean by past det.? That crap stays in there or something? Thx.
Ant.
Old 09-17-2004, 08:39 PM
Rogers Performance's Avatar
The aluminum balls are from detonation.You need to find out why that cylinder is detonating.
mike
Old 09-17-2004, 08:50 PM
docvette's Avatar
Wiki Edits: 12
Detonation
Doc here
Right on Rodgers!
What I meant about "Past Detonation" was , since you say you reset your timing, It shouldn't be detonating anymore...
Try a better boost, NOT Snap...
Doc
Innovations
Old 09-17-2004, 11:58 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
lol, looks like your octane booster was made out of dog schit.
K
Old 09-18-2004, 07:00 AM
1BAD80's Avatar
Wiki Edits: 2
One other question is why do you need the octane booster.
What compression are you running ?
The balls are from the junk thats made in the formula for the booster.
Change the plugs also.
Try some Marvel Mystery Oil instead of the booster, it does the same, only better.
This has been discussed many times before on this Forum.
