Help with spark plug selection, currently running autolite 25 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 12:40 AM
I have a 388 sbc with world product sportsman heads, holley street dominator carb and 650dp. Upon pulling the plugs the car has been running rich and it has been suggested that I run one step hotter of a plug. Is this wise or could this cause me trouble? Thanks.
Old 10-25-2010, 08:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Just throwing in a hotter plug will not fix a too-rich carb calibration, and in a worst case scenario could cause detonation.
So, what you need to determine is if the engine is running rich or if you have too cold of a plug heat range. Also you need to be sure that what you're seeing isn't oil fouling.
To begin with, set the idle mixture w/a vacuum gauge. The timing curve has to be correct as well. Be sure the air filter is adaquate and the lid isn't too close to the vent tubes.
To do a quick check for primary calibration, you need to run the engine up to where it's mostly on the main circuit (~2500 RPM) and partially choke the air flow into the carb. If it picks up speed, you're on the lean side, slowing is on the rich side. A little lean or neutral is where you want to be.
Do a plug chop to see what the secondary side "looks" like.
2001 Nissan Altima Spark Plug Wires awbazar Electrical 5 11-07-2010 01:47 PM
Questtion on spark plug heat range. eric32 Engine 4 11-10-2009 06:23 PM
spark plug gap at zero ? mannasugar Engine 6 05-30-2009 12:04 PM
Spark arcing outside the plug?? 85MonteSS Electrical 16 11-16-2004 10:02 PM
Weird spark plug situation?? Jim Weeks Engine 4 05-13-2002 07:32 PM
